ALLIS B and C
TS
12-22-2005 04:53:17
Aneyone installed a 3 7/16 engine kit from TISCO and had it on the Dino to see how much power they made? I an thinking of installing one and wanted to get a idea how much HP they made.
steve(ill)
12-22-2005 17:32:37
 Re: ALLIS B and C in reply to TS, 12-22-2005 04:53:17
it is only 1/16 overbore so dont expect more horspower over original. you will get a good increase over the present tractor motor which probably leaks around the rings and valves. to get more horsepower you will need to increase the engines speed 200 RPM, maybe plane the head .100 inch to raise compression to newer levels, etc. porting the head and putting in a slightly bigger main jet might help if several other things are done first.--- for a day to day tractor, you dont need more horse power, the B is plenty strong as is.
TS
12-25-2005 09:07:38
 Re: ALLIS B and C in reply to steve(ill), 12-22-2005 17:32:37
I was thinking of it beening a puller and any other info would be appreated.
