HD6 E HYDRAULIC PRESSURE
K Wiggins
12-21-2005 11:13:53
Hi Does anyone have the expected hydraulic pressure for an HD6 E at the steering clutches and blade. I Suspect problems with either pump, oil or something on the oil system, as the blade is slow to lift and the brakes dont seem to work when hot (I think they are hydraulically operated) which affects steering, but I think the steering clutches are ok as it steers fine when going up an incline and gravity does its job to steer when the clutches are disengaged. Any help on this matter would be appreciated.
ACPhil
12-26-2005 08:37:09
 Re: HD6 E HYDRAULIC PRESSURE in reply to K Wiggins, 12-21-2005 11:13:53
I have a few books on the HD6E. I will look and see if I can find any diagrams or solutions to your problem. Good Luck, Phil
Stan (NCMO)
12-22-2005 09:34:11
Try putting your question over in the Dozer forum and/or got to www.ibdozing.com.
