D15 Series II Gear Lub?
Henry j
12-21-2005 04:49:50
I just purchased a D15 Series II to keep my green and yellow tractor company in the barn. After reading the ops manual and going thru the archives, here is what I plan on using for gear lube.
hydraulic - 20 W as recommended
Power Director - 20 W as recommended uless someone has had better results with something else.
trans and finals - I have lots of 80/140 setting around and plan on installint that. Is there a special reason why the 20W is recommended for the finals? Gees, I use straight 140 in the green machine.
Thanx
Kent of SW MO
12-21-2005 07:05:45
 Re: D15 Series II Gear Lub? in reply to Henry j, 12-21-2005 04:49:50
The 20 W oil was used before the Allis 303 hyd. oil came out. I think the drop box finals still use 80W-90. You can use Universal Hydraulic oil to replace the 20W.
Kent
