AC cylinder compression
Ray Norlin
08-01-1999 20:09:07
I have a'47 B Allis that I need to know the normal cylinder compression ratio. The readings I am presently getting are 85,77,90,90. The tractor was in a heavy rain with no protection over the vertical exhaust pipe. I removed the plugs, spun the engine to blow out the water from the cylinders and changed the oil. the tractor will start but runs poorly. All electrical components appear to be dry and it seems to be getting enough fuel. It starts easily and idles well but misfires and has no power when under a load. Any help would be appreciated.
Carroll Porter
08-02-1999 18:40:30
 Re: AC cylinder compression in reply to Ray Norlin, 08-01-1999 20:09:07
I'd check for water in the tank,sediment bowl,and/or carburetor. Could be bad points, or the mechanical advance not functioning properly. your compression test results sound just fine. CP
Don K.
08-02-1999 07:12:39
I checked mine not too long ago and the compression was 95 across all cylinders.
Don K.
08-02-1999 07:10:57
