WD rear wheel weights
erik
08-01-1999 19:34:37
I have 2 sets of rear wheel weights, one for a WD and one for a WD45. One set has holes for 4 bolts on each weight, the other set has 2 holes on each weight. Which set is original for a 1953 WD, the one with 2 holes or the one with 4 holes on each weight?
Paul
08-02-1999 15:56:38
 Re: WD rear wheel weights in reply to erik, 08-01-1999 19:34:37
erik, the ones with 4 holes should be for WDs or WD45s both used the same weights. Sounds like the other ones with 2 holes might be WC weights,hope this helps, Paul Anderson
