Rebuilding Original Air Cleaner on a B
Whiskers1949
12-15-2005 16:38:50
I finally got an original air cleaner, and of course, the screen material is all gunked up with crud. I suppose I could get some screen wire, cut it into strips, fold it just so, and cram it down in there like the factory did. Anybody got other ideas?
Jerry Coulter
12-16-2005 08:34:56
 Re: Rebuilding Original Air Cleaner on a B in reply to Whiskers1949, 12-15-2005 16:38:50
We cleaned many of those. Break the spot weld and remove the tin that holds the mesh in. Take out the mesh and unroll it. Wash off the gunk. Roll the mesh back up over something round the same size as the tube in the air cleaner. Slide the mesh back into the cleaner and spot weld or solder the tin back in place.
w.h.king
12-15-2005 16:52:20
You can put it in a parts washer and leave it for about a week! And, you can get it boiled at your local radiator shop. I have had good luck with the parts washer though. good luck
Whiskers1949
12-16-2005 05:15:03
 Re: Rebuilding Original Air Cleaner on a B in reply to w.h.king, 12-15-2005 16:52:20
Good ideas, but I"m gonna have to disassemble it to remove a large dent in the side of the main chamber. Of course, the job will be a lot neater with a clean unit to start with!
