WD won't start!
Puller504
12-14-2005 15:00:53
I'm stumped. Went out the other day to fire up the WD and get her inside for the winter. No start! Got spark, (electronic ignition), got fuel, Battery's at full charge. Spins over like it's on steroids but won't fire? It's below 20 degrees outside, carb iceing up? Anyone got any suggestions? Changed plugs and wires, old plugs were worn out and smelled of gas, she still won't fire, but has plenty of spark! Thanks in advance for any helpful ideas! Don
Puller504
12-17-2005 07:52:41
 Re: WD won't start! in reply to Puller504, 12-14-2005 15:00:53
WD update: got back down to the farm and drained the (brown) gas from the carb. Tractor now fires off at an idle but dies when opening the throttle. I"ll pull the carb this week and clean/inspect it, it may be time for a carburator rebuild. Thanks for all your helpful ideas, Happy Holidays! Don
Guyzoo
12-16-2005 05:43:42
Try putting gas in each cylinder
HTH
Dave Grubb
12-15-2005 10:18:03
Might be the fuel tank had water in the bottom of it that has turned to ice and shut the fuel off. Did you check the air filter bowl to see if it was full of frozen condensation and has shut the air flow off?
John (MO)
12-15-2005 06:12:17
Are the plugs wet? It"s possible you aren"t getting enough suction out of the cylinders to pull fuel and air into them. If the plugs aren"t wet, try spraying a little WD-40 into the cylinders. If will seal up the rings until you can get a little fuel/air pulled in to burn. Could also be that you"ve got a manifold leak and you are pulling air but no fuel. Just something to check in to.
Bill(Wis)
12-14-2005 20:49:33
Spark orange or blue?
orange-mud
12-14-2005 19:19:52
Next time you fill your tank, try using non-oxygenated fuel. I never have a problem starting my wd-45 since I started using non-oxy. Fires up on the first crank!!
Aaron SEIA
12-14-2005 15:21:41
Did you try a sniff of ether? Mine did the same thing last week. Wouldn't even pop on the good stuff up it's nose. Dumped the sediment bowl and drained the carb. Fired right off after that. Even took right off 3 days later when it was 5 out.
Aaron SEIA
