Sleeves in WC
Colo Don
06-24-1998 19:35:56
I started a '39 WC by pulling and it took (after 25 years of sitting). Blew out lots of mice nests and a pile of rust flakes!!! Then froze. Tore it down and found # 4 intake valve broken and broken piston. Cyliders in good shape, that is barely detectable ridge. But ... I scored # 4 cylinder a bit with the broken piston ans rings.
How much of a chore to remove the sleeve and replace? How do I go about it. The manual just says remove with proper puller.
Don E. Foster
Paonia, CO
grapeape
06-26-1998 06:16:11
 Re: Sleeves in WC in reply to Colo Don, 06-24-1998 19:35:56
: I started a '39 WC by pulling and it took (after 25 years of sitting). Blew out lots of mice nests and a pile of rust flakes!!! Then froze. Tore it down and found # 4 intake valve broken and broken piston. Cyliders in good shape, that is barely detectable ridge. But ... I scored # 4 cylinder a bit with the broken piston ans rings.
: How much of a chore to remove the sleeve and replace? How do I go about it. The manual just says remove with proper puller.
: Don E. Foster
: Paonia, CO
hi there don, you can remove the sleeve without pullers if its not stuck to badly. the cylinder liner can be driven out with a drift from the bottom. after removing the oil pan, you can see the bottome edge of the sleeve protuding from the water jacket. be carefull not to make a mishit and damage the crankshaft! but usually the sleeve can be removed in this manner. ive been involved with allis chalmers all my life and have seldom had to use the sleeve pullers. but it is possible with an engine this old and obviously neglected for so long that you may need to resort to the pullers. good luck, grapeape
colo don
06-26-1998 17:50:37
 Re: Re: Sleeves in WC in reply to grapeape, 06-26-1998 06:16:11
: : I started a '39 WC by pulling and it took (after 25 years of sitting). Blew out lots of mice nests and a pile of rust flakes!!! Then froze. Tore it down and found # 4 intake valve broken and broken piston. Cyliders in good shape, that is barely detectable ridge. But ... I scored # 4 cylinder a bit with the broken piston ans rings.
: : How much of a chore to remove the sleeve and replace? How do I go about it. The manual just says remove with proper puller.
: : Don E. Foster
: : Paonia, CO
: hi there don, you can remove the sleeve without pullers if its not stuck to badly. the cylinder liner can be driven out with a drift from the bottom. after removing the oil pan, you can see the bottome edge of the sleeve protuding from the water jacket. be carefull not to make a mishit and damage the crankshaft! but usually the sleeve can be removed in this manner. ive been involved with allis chalmers all my life and have seldom had to use the sleeve pullers. but it is possible with an engine this old and obviously neglected for so long that you may need to resort to the pullers. good luck, grapeape
Just had an oldtimer (well not as much so as I am) tell me to put dry ice in the sleeve and lift it out by hand!!! Do the same with the new insert!!! Sounds logical.
