Front End Loader for 1956 CA
RogerS
12-12-2005 07:01:12
Is there a front end loader (original or after market) for the 1956 CA? Are they hard to come by?
John in KS
12-12-2005 17:04:10
 Re: Front End Loader for 1956 CA in reply to RogerS, 12-12-2005 07:01:12
The original was a Number 8 or sometimes called a WD8. It is a trip bucket loader and the subframe mounts to the rear axle housings and to a side bar that hooks up under the engine. The main frame is the same one used for the WD and WD45 and I see them fairly often, but have yet to see a subframe for the Number 8. I'm sure there are some out there somewhere. There are probably some aftermarket loaders made for the CA, but I don't know much about them. Just remember if you find an aftermarket you need to make sure the cylinders are high pressure.
