Sticky B clutch
jeffalex2
12-11-2005 16:52:37
I've lubed the bearing and adjusted the fingers, but my little B clutch still sticks. Just a tap of the brakes gets it to free when on the move. Kind of a pain at cold start though...should I hit the plates with brake cleaner? Or just pull it apart and do a new clutch? Thanks!!
wdtom
12-13-2005 18:09:58
 Re: Sticky B clutch in reply to jeffalex2, 12-11-2005 16:52:37
Another thing you could consider that could be causing the problem is the pilot bearing in the end of the crankshaft fitting too tight on the clutch shaft. Had this problem and it was exactly as you describe. Once it broke free it spun OK but until that happened it was like the clutch was stuck. Had to split the tractor and emery cloth out the bushing just a bit, doesn't take much as it fits alredy. You just need a couple of thousands clearance maybe.
steve(ill)
12-12-2005 16:00:34
what is happening is the rear seal on the motor leaks very slowly and has the plates coated with oil over the years. you need tp block the pedal down, then wash the plates. you can spray fromt eh bottom with a weed sprayer, but it works very good to pull the starter and spray thru that hole. mix laundry soap with a gallon of warm water. soak it real good till it runs out the bottom, rotate 90 degrees (turn fan) and do it again, do this 4 times. should be o.k. for another 60 years after that.
Stan(PA)
12-12-2005 10:17:50
When it is free, try "slipping" it a little. It may polish the surfaces just enough to clear it up.
old
12-11-2005 18:36:16
Its a common problem with tractors. What happens is the clutch plate rusts to the fly wheel and preassure plate and sticks. One way to keep it from happening is to block or tie the clutch pedel down when your not useing the tractor.
