B Model Bearings and Seals
Tony Reed
07-30-1999 06:02:53
I need to replace the bearings and seals on the rear stub axles of my "B". As far as I know, they are the original bearings and seals. I've removed the inside cap and the bolt that holds the axle in place, but the inside bearings seem to be holding the axle in place. Is there any trick to getting the inside bearings off? Also, does anything else hold the axle in place? Any help would be greatly apprecated.
Thanks,
Tony
Brian Goodfellow
08-04-1999 06:56:46
 Re: B Model Bearings and Seals in reply to Tony Reed, 07-30-1999 06:02:53
Before you go any further, I suggest you get an I&T service manual (#AC-11). There is a large nut and lockwasher on the axle on the inside of the bull gear. You have to remove the pan off the housing to get at it. According to the manual, after you loosen this nut, you have to drive the axle towards wheel side (using a SOFT drift) until you can unscrew the nut completely. The axle then can be pulled out from the wheel side. It doesn't mention it, but make sure you don't let the bull gear drop on the floor when you do this! If the seal surface is pitted badly, E-mail me and I'll tell you how I cured that problem on my WD. Again, I don't recommend attempting any serious repairs without a manual. It will save you a tremendous amount of time and AGGRAVATION!
