WD45 crank
Maark
12-08-2005 13:09:28
I'm putting a new crank in my WD45. Took it in to be turned, it was cracked. Bought a new one. The service manual says to put 4 shims on each main cap. My crank only had 1 shim per side. Do I need to make shims, or what?
wdtom
12-11-2005 18:29:17
 Re: WD45 crank in reply to Maark, 12-08-2005 13:09:28
You need to understand what you are doing with shims and bearings. Look back a few pages or search the archives. I have posted how to do it. Get a reprint manual or a I&T. Basically you need .0015" less shims on each side of the cap than the gap between the cap and rod or block. You need to check clearences with plastigauge. I install the bearing shells dry and finger tight, maybe tapping a little with the handle of a screwdriver to settle them. then measure the gap, getting it even on both sides. Now make your shims .0015 less on each side. check with lastigauge.
Zonie
12-11-2005 16:14:48
I have new shim packs available for you if you want them. Give me a call at 520-834-4242 John Brock
J.C. IN AZ.
12-11-2005 08:59:10
The more Shims, the more eliptical the Bearing becomes. Ideally no shims is perfect. The use of Plasti-Gage is highly recommended.
knauffj
12-11-2005 06:10:12
I got my shims from an Agco Dealer. Not very expensive. The machinist should have been able to machine so you wouldn't need the shims. As said before, plastigage is very important when reassembling.
RICEDADDY
12-10-2005 21:54:58
MAARK, THE BOOK SAYS USE FOUR(4) SHIMS ON A NEW CRANKSHAFT, SO YOU WILL HAVE TO TALK TO WHEVER TURNED IT TO SEE HOW MUCH HE TOOK OFF tHE BEARING INSERT SHOULD STAND OUT ABOVE THE BLOCK AND CAP .0055" ON EACH SIDE
oops caplock, sorry
good luck
Ron
Tom in Michigan
12-08-2005 15:56:23
Maark, The machinist who sold you the crank or turned it should be able to tell how much has been turned off of the crank; .010, .020, .030 etc. He should supply the appropriate bearings to you. You should also use plastic guage to determine the clearance between the bearing and mains and also the rod bearings. This is very critical. Check the manual for this clearance and add shims as necessary. When I have a crank turned, the machinist supplies the bearings based on how much was taken off. Most engines don't have shims - the bearings are sized based on what was ground off of the crank. Tom
