WC cranking info needed
van robinson
12-07-2005 23:12:42
Did any of these have electric start or all hand crank? When using the hand crank, is there any special procedure to follow to crank it like on a hand crank John Deere A, such as pitcocks to open?
WCPULLER
12-08-2005 19:24:50
 Re: WC cranking info needed in reply to van robinson, 12-07-2005 23:12:42
OR JUST PARK IT ON A HILL. HAND MY WRIST BROKEN 2 TIMES AND IT HURT LIKE A -----.
old
12-08-2005 08:12:21
A lot of the WCs had starters on them they where 6 volt but did a good job. I have a WC speed patrol with eletric start which is just a WC tractor made longer and a grader blade put under it but its still a WC
Aaron SEIA
12-08-2005 04:37:16
Owned a crank start one for a while. No real special procedure. Just make sure the clutch is disengaged, there is a lock for the pedal. Always pull up on the crank and do NOT wrap your thumb around the handle. Just cradle it in your fingers and pull up quickly. Only had mine roll back on me once, hurt like the dickens though. Arms can be broken hand cranking, but if it's tuned up right, it's no problem. As for starters, I think the 38 and up had them. The very last of the unstyled and all the styled ones did. It's fairly simple to convert one to electric. Just need to get an electric start bell housing and all the starting equipment. Aaron SEIA
