Possible allis WC? HELP!!
van robinson
12-07-2005 19:25:48
I have come across what i believe to be an Allis WC. Please go to the Help Identify section to see pics of it. They are listed under Allis WC? and several under another pic with my name van robinson out beside them. the engine is free as i turned it with the crank handle. The owner wants $1000 for this. Is it worth that? Where would i find a serial number and model number tag? What year were they built? Thanks in advance.
John (C-IL)
12-08-2005 06:13:47
 Re: Possible allis WC? HELP!! in reply to van robinson, 12-07-2005 19:25:48
third party image
Amazing condition for a hedge row classic, but no more than $500. The steel wheels would be worth that to a parts guy.
gene (missouri)
12-07-2005 21:32:13
My question is what do you want in a tractor - or why an unstyled WC. If you are looking for a work tractor the WD series and up would be a much better work tractor. If you want a neat looking play - parade tractor then the unstyled WC.
I own a 36 WC. $1000- is a bit much.
Gene
J.C. IN AZ.
12-07-2005 21:28:09
It is in Bad shape,It is not rare,The Steel Lugs limits its mobility for show, I would offer $300.00 no more and at that a lot has to be done to bring it to Pride of Possesion shape.It would make a good Yard Ornament if cleaned up. My opinion.
old
12-07-2005 20:43:57
I'd say $1000 is way to much. I picked up a WD this summer with good tires and all it needed was a tune up to run and only payed $250 for it. And it was parked in a garage and had been in there for years. I'd say maybe $500
Michael D.
12-07-2005 20:08:25
third party image
Yes it is a WC. Probably a 36 or 37. Serial number is in on the differental above the plug. $1000.00? You have to determine that. Full steel if in good shape a plus in my book. Does it have the small round gas tank under hood by radiator? If it does another plus. Radiator hold coolent? The blocks have a tendency to crack just under the carb. The fenders are in OK shape and can be straightened by a good body man. That just a few things to look at, by no means am i an expert. My son bought a running 35" WC 1400 miles from home for $800. We have bought seveal bolt on parts and done some mechanical work with more to do before we are finnished with it. Good luck and have fun thats what its all about with these old tractors, not money! LOL! Mike
Eldon (WA)
12-07-2005 20:04:29
I'd say about half that....
CHALMERSBOB
12-07-2005 19:55:31
THE SERIAL # IN ON THE REAR PUMPKIN. IT IS ENGRAVED INTO THE STEEL ON A FLAT SPOT, NO PLATE.
BUILT FROM 1933 TO 1948. DON'T THINK ITS WORTH THAT MUTCH. I'D WANT TO HEAR IT RUN FOR THAT. EXCEPTION MIGHT BE IF SHEETMETAL IS PERFECT, ALONG WITH GOOD TIRES. BOB
dan wc ne wyo
12-08-2005 17:51:08
 Re: Possible allis WC? HELP!! in reply to CHALMERSBOB, 12-07-2005 19:55:31
Hi Bob, lots of work there, and also a magneto to supply from the picture. I would be interested as is for 500.00 tops. good luck. dan wc ne wyo
