tach cable part
D17JIM
12-07-2005 09:04:12
SOMEONE FROM THIS FORUM SENT THAT I COULD GET THE SMALL DRIVE FOR THE END OF MY TACH CABLE ON MY D17 AT AGCO. MY CLOSEST DEALER (WHICH IS OVER AN HOUR AWAY) CAN'T SEEM TO FIGURE OUT WHAT I NEED.
HE WANTS $40 TO ORDER ONE AND I DON'T THINK ITS THE CORRECT PIECE. I JUST NEED THE PIECE THAT THE CABLE SLIPS INTO AT THE DISTRIBUTER. MY DRIVE PART THAT SLIPS INTO A GROOVE ON THE DISTRIBUTER IS GOOD SO I ONLY NEED THE PART THAT SLIDES INTO IT AND THE CABLE SLIDES INTO THAT . I WOULD CALL ANOTHER AGCO IF I KNEW WHERE ONE WAS AND HAVE THEM MAIL IT. NAPA WAS NO HELP. THANKS JIM
JMS/MN
12-09-2005 06:59:53
 Re: tach cable part in reply to D17JIM, 12-07-2005 09:04:12
FYI- dealer locator is at www.agcocorp.com
DON DITTMAR
12-08-2005 05:41:06
AGCO PART NUMBER 234221 IS THE ADAPTER NUMBER IF ITS AN OLDER TRACTOR. CALL ORMSBEE IMPLEMENT AT 231-238-9928 AND TALK TO STAN. THEY ARE MY LOCAL AGCO DEALER AND I HAVE ADVISED HIM OF YOUR PROBLEM AND TOLD HIM YOU MIGHT BE CALLING. HAVE YOUR TRACTOR SERIAL NUMBER BECAUSE THEY MADE 2 DIFFERENT DRIVES AND YOU MAY NEED A DIFFERENT DRIVE.
D17JIM
12-08-2005 07:12:56
 Re: tach cable part in reply to DON DITTMAR, 12-08-2005 05:41:06
Don: Thanks, Stan was a real help. I'll go this way and he should fix me up after I get the cable # so he gets me the right one. Lots of help. Thanks again !!!!!Jim
DON DITTMAR
12-08-2005 10:07:39
 Re: tach cable part in reply to D17JIM, 12-08-2005 07:12:56
GLAD TO HELP JIM.
D17JIM
12-12-2005 13:20:54
 Re: tach cable part in reply to DON DITTMAR, 12-08-2005 10:07:39
DON, I WANTED TO LET YOU KNOW THAT STAN HAS SENT MY PART. HE WAS VERY FRIENDLY AND ACCOMODATING. BETTER THAN MY LOCAL AGCO DEALER DID NOT TRY VERY HARD AND I'VE KNOWN HIM A LONG TIME. SO THAMKS AGAIN. JIM
DON DITTMAR
12-08-2005 05:30:16
I WAS THE ONE THAT REPLYED TO YOU JIM. WHEN I REDID MY D14, THE TACH WOULD NOT WORK. I LOOKED AT THE PARTS BREAKDOWN AND THERE IS A SMALL PLASTIC PIECE THAT FITS INTO THE ADAPTER IN THE DISTRIBUTOR. YOUR TACH CABLE FITS INTO THIS PPLASTIC PIECE. I AM ASSUMING THAT D14 AND D17 ARE THE SAME
D17JIM
12-08-2005 02:48:09
Thanks guys !!!! I checked out NAPA and no luck with the kits. I'll try Heavy Duty Trucking at Terre Haute, (only 15 minutes away). I just never thought abuot over there. Appreciate it and I'll let you know what I find out. Jim
Gatz
12-07-2005 09:26:05
I tried buying just the inner flexible cable for the tach on a D17diesel.
AGCO dealer couldn't supply just that part; they only sold it as a new assembly. Seems it was around $48.
Ended up buying a cable kit from NAPA and it worked fine.
Not sure if the end piece for a gas and a diesel are the same or not, but NAPA had various ends that you could get with the kit. Might take a look if they're local.
Bob
12-07-2005 19:58:05
 Re: tach cable part in reply to Gatz, 12-07-2005 09:26:05
Also check at a heavy truck (semi) dealership. They have ends like that for use with truck speedo and tach cables.
