allis-b
Bruce L.
12-06-2005 18:08:25
looked at a allis-b with lots of things wrong most likely a parts tractor the thing i am lost on is the shifter he said could not get out of gear and forced it says he might have bent shifter i would say broke it the shifter spins in a circle ? yes circle could it just be sfifter at the forks ? is this part that must be broke hard to find and fix? wish that was all that is wrong with the b
Thanks
Bruce L.
steve(ill)
12-08-2005 18:22:28
 Re: allis-b in reply to Bruce L., 12-06-2005 18:08:25
right side of the transmission next to shift lever, there is a 6 inch diameter steel plate with 4 screws. take the plate off and the forks and slide pins are attached to that. with it out, you can see the shift lever ball on the end. not dificult to repair anything in there
LeRoy DeLong
12-07-2005 05:46:35
If you decide to part out the Allis B, I would be interested in the the drawbar.
jeffalex2
12-07-2005 03:45:19
We had a similar problem with a Farmall H. Instead of buying the new part, we welded the old fork back together and spent about an hour grinding and 'primping' before reassembly. Been good for 5yrs of field work so far. Was not a tough fix.
