what is it?
herkpilot
12-02-2005 21:15:23
I'm being basically give a tractor and I think it's an AC. I can't find a serial number but there are some numbers off the transmission are ad a couple other places.
Transmission# is 2663J-EE. Motor# is 375596R1. Another # is 375576R1.
Any help's appreciated. Tough to fix if you don't know what it is.
gene (missouri)
12-03-2005 06:23:38
 Re: what is it? in reply to herkpilot, 12-02-2005 21:15:23
Take several photos of the tractor. Visit the coffee shop frequented by the local farmers. Try the local tractor dealer or an auctioneer.
Gene
Kent of SW MO
12-03-2005 04:45:02
The R1 on the ends of the two number makes me think International.
Kent
cbp
12-03-2005 04:27:26
Could you post a picture so it can be established what make and model it is. If not (I know how that goes, my digital won't work), you can start with serial number and work out but it's a lot of research. The serial numbers are always stamped numbers and not cast numbers. The cast numbers might indicate a brand, for example a six digit casting number proceeded by AM would indicate a certain manufacturer but it's a hard way to go. Most of the people on the site and in any of the boards here can tell instantly by photo. Then the serial number can nail it to the year.
You could also go through the photos at tractorshed.com and see which picture it looks like it. Once you've done that, you can look in the serial number list for the model it appears to be it see where the serial number should be. Then the right number to identify the year will be easy to find.
If one of those numbers is really the engine number and one the tractor serial number, a likely wrong guess is it may be a later farmall. Really need more information.
