Plowing with my WD
K. Richardson
07-29-1999 18:25:02
Hooked up the 3 bottom 14 plow to my WD for the first time today. I did not clean the plow blades, so I didn't expect much. I didn't go at it for too long either because it is too hot out today. It should be fun once I get everything adjusted right.
Gordon
08-13-1999 12:26:26
 Re: Plowing with my WD in reply to K. Richardson, 07-29-1999 18:25:02
I wish you all the luck in the world. If you are plowing soft, sandy, loam, soil that is clean and with just the right moisture you may be OK. The best I can do with with my WD (in plain old clay dirty dirt) is to pull a two bottom AC Plow. I can pull it fairly well/fast, but only after lots of tweaking. Be careful of the hook up of the plow. If it comes lose while you are plowing, it is BAD, VERY BAD! You may wish to check my post of 8/13/99 on the subject of WD Plow hook up.
