WD-45 Disk
Phill Snartland
12-02-2005 10:41:40
Hi All,
I have a '54 WD-45 that I restored last year and I'm anxious to put it to work. I have a 3-14 plow that I'm working on getting into useable condition. I'm also wondering about a disk for this tractor. How wide a disk can a WD-45 pull? I live in central MN. Does the disk width make a difference if it's a mounted Snap-Coupler version or a pull-type? I've seen 8', 10' mounted ones, and 12' and 13' pull-type ones. Don't know what to focus in on.
Thanks for the help!
chester dubois
01-08-2006 20:11:45
 Re: WD-45 Disk in reply to Phill Snartland, 12-02-2005 10:41:40
well i can pull a 15 ft disk with dulls on in 2 gear but i usaly pull a 13 ft in 3 gear with a cullapaker or drag it dose a good job but if ur in plowed ground or chisled ground then i would wieght the 45 down cause u will loose traction going up hills in that type of ground well i hope u have fun good luck
ricedaddy
12-11-2005 17:37:11
another factor is whether your pulling a cutting disk or a pulverising disk, makes alot of difference.
ricedaddy
12-11-2005 17:36:34
Phill Snartland
12-05-2005 06:10:46
Thanks for all the responses, guys! Now I can go looking with some confidence.
Have a Merry Christmas,all!
Phill
mtgummibear
12-04-2005 10:43:59
Since my dad farmed in Minnesota, I'll add my two cents worth. He farmed for years with a WD and WD-45 and my memory is that he used a 12-foot tandem disk. This was a wheel carry, not semi-mounted.
This was in SW Minnesota near Marshall so the soil can't be too different than where you are.
Larry
RickM (MO)
12-02-2005 17:51:59
It's been a long time ago, ('50's - 60's) but we used to pull a 13 ft. Snap Coupler semi mounted disc with no problem in any ground with a '57 WD-45. With no duals either, although duals do help a whole lot in plowed ground. Pulled a 9 ft. Kewaunee pull type with a straight '51 WD under same conditions. Both '45 and WD had CC in rear tires and '45 had double weights on rear.
BushogPapa
12-02-2005 15:27:37
With a like new IH #37 disc, we eventually got a set of snap-on duals and were very happy we did....
Even with very good loaded rear tires, we had far too much wheel slippage in 1st time over plowed ground...the duals almost let the WD-45 walk on water...!!! IMHO.... Ron..
Butch(OH)
12-02-2005 13:21:57
How big a disk it will pull decently depends on what kind of disk you are talking about. With no weights or fluid and a drag disk of other make wheeled or not your limited to 8' in tougher going maybe 10 in better going. With an A-C mounted or semi mounted and an operator who knows how to set the traction booster a 12' is no big deal behind a 45. The #212 12' disk was designed for the 45.
Dave (NE)
12-02-2005 13:11:51
My '45 easily pulls the 10' snap coupler disc I have. I have also used it on the 12' wheeled disc, but not put it into the ground too far, and no problem. Actually a lot of fun.
old
12-02-2005 11:15:22
I would guess about an 8 foot maybe 10 foot but not much is any more. Its always better to have less disc and a little power left over for the ruff spots.
