GLEANER E NEED HELP AND PARTS
Dean SE Nebrask
11-30-2005 15:39:41
I just bought a gleaner E and am trying to fix it up. It runs really good and its pretty well ready to go except some of the parts that are not attached really well to the combine such as the Feeder beater sprocker. The other parts I need are a lower cleaning fan Sprocket. A set of Cylindar speed sprockets and a three row cornhead I.E. 330 model number. I would also like information such as what is the tool that hangs on the clean grain elevator and any stories of these machines. Your help is really appreciated thank you.
Dean.
legn4
12-01-2005 16:47:09
 Re: GLEANER E NEED HELP AND PARTS in reply to Dean SE Nebraska, 11-30-2005 15:39:41
Dean, Also that tool is used to push in the 4 pins in the throat that holds on the head.Look for the little 1/4" sq countersunk area- very handlie tool. I have junked out 4 E,s for the motors.The remains (less some parts) are deer stands now lol.Have a 65" E coming in same deal.On my K it has a F 330 head thats been fit to it. That may be a ideal also for you.Iam a hour east of K.C. Mo. if your in the area some time. Eddie
Duey (IA)
11-30-2005 18:11:49
Dean,
When you replace a bearing or move a bearing to adjust a chain etc.,always remember to loosen the bearings on both ends of any of the shafts so the bearings can realign. This machine should be able to be turned by hand, if no bearings have alignment pressure on them.
Be sure the machine clutch is adjusted up so it snaps in place and always start the machine with reduced engine RPMs..... ..the same with starting out in high gear..... saves on belts and clutches.
Tim(nj)
11-30-2005 17:55:47
Worthington Ag Parts (findable by a google search, etc.) will have a variety of used parts for the E. They must have at least 100 of them in their yards. Some stuff is still available new from AGCO. As far as finding an E330 head, good luck. Not that many were made, and of those that were built, most have gone to China by now.
JMS/MN
12-01-2005 10:02:54
 Re: GLEANER E NEED HELP AND PARTS in reply to Tim(nj), 11-30-2005 17:55:47
Worthington Ag- 1-888-845-8456.
david from mo
11-30-2005 18:43:08
My brother has a good 330 head he bought new .It has been changed over to fit his K. He has a F2 and 430 head now ,we are in north central Missouri
Dean SE Nebraska
11-30-2005 20:04:50
 Re: GLEANER E NEED HELP AND PARTS in reply to david from mo, 11-30-2005 18:43:08
Would you want to sell it? How hard would it be to change it back to fit on an E?? Cuase I would really like to get one.
den/southern illinois
11-30-2005 16:23:27
The tool hanging on the combine is most likely the rock door reset tool. If that is what it is...guard it. If you ever have to close the rock door...you will want it and not a makeshift tool...hard on the body without it as I have been told. Den
JMS/MN
12-01-2005 10:07:03
 Re: GLEANER E NEED HELP AND PARTS in reply to den/southern illinois, 11-30-2005 16:23:27
The tool is also used to compress the spring on the underside of the throat- to lock or unlock the head to the combine. Round end of the tool is hollow, fits over wedge on spring. When closing the rock door- DO NOT lay under the combine with the tool between your legs and pull the door shut. Hold along side of you- it can snap with quite an impact, and unless you want to change choirs next Sunday..... .
Dean SE Nebraska
12-01-2005 15:45:34
 Re: GLEANER E NEED HELP AND PARTS in reply to JMS/MN, 12-01-2005 10:07:03
so what your sayin is that if the wrench happens to slip it could tickle just a little bit?
