WD45 Carburetor
SEK
11-30-2005 10:38:46
I need to rebuild the carburetor on my WD45. Are there any good how to videos that would help me. I'm not much of a mechanic, but I can follow directions.
BCnT
11-30-2005 13:56:13
 Re: WD45 Carburetor in reply to SEK, 11-30-2005 10:38:46
it would take longer to watch the video than to actually rebuild the carb...theres nuthin to em...2 bolts and carb is off...4 screws and bowl is off...unscrew everything with a hex head or slot and drop the whole shebang in a bucket of good non enviormentally friendly carb cleaner overnite...pull it out next day and hose it off...blow all passages out with air hose and start reassembling...make sure you get main needle seat tight so it doesnt leak past when float closes needle...once you get float on turn carb top over and eyeball float to top of carb...gap should be even...put bowl on and screw both needles in all the way and back off 1.5 turns...that will get it started...let it warm up and fine tune...thats it in a nutshell
keep in mind the cleaner the better.
good luck
