ac-c upgrade
gary case
11-30-2005 08:51:36
got a 41 c and would maybe like to put a starter on. alternator also perhaps. just didn't want to spend more on a str. and alt. and the other stuff it will take than i spent on the tractor. how hard is it for the average joe to do? thanx gary
BCnT
11-30-2005 14:01:12
 Re: ac-c upgrade in reply to gary case, 11-30-2005 08:51:36
if your tractor doesnt have the starter type torque tube you will have to split the tractor and put one in...ring gear on flywheel while you got it apart...after that its easy
gary case
12-01-2005 07:38:58
 Re: ac-c upgrade in reply to BCnT, 11-30-2005 14:01:12
thanx bc, it's got the starter hole.now what would i need to do it,please. thanx gary
BCnT
12-01-2005 13:27:33
 Re: ac-c upgrade in reply to gary case, 12-01-2005 07:38:58
well...if its got the hole and the ring gear is already on flywheel i'd say ya need a starter,actuating rod,couple cables,a battery,and a handfull of nuts n bolts...since you mentioned an alternator too may as well go negative ground from the get go and a 12 volt system...since you dont have much experience i'd suggest getting parts and service manuals for your tractor so you can actually see how everything goes together...
once ya get starter hooked up a true 1 wire alternator would top it off.
gary case
12-01-2005 15:04:57
 Re: ac-c upgrade in reply to BCnT, 12-01-2005 13:27:33
thanx alot BCnT. THE COMPLETE SET IS IN THE MAIL, SHOULD BE ANYDAY. PICKING HER UP SAT..THANX AGAIN GARY CASE-CHALMERS.
