Allis C steering
Richard G.
11-30-2005 06:52:56
Got a C running after setting in a barn for years. Did all needed repairs and fresh paint job. Drove it around a while and delivered it to owner. After setting a while the steering locked up. It was steering fine before I delivered it.
Any ideas or suggestions?
Thanks, Richard
chalmersbob
12-01-2005 19:36:59
 Re: Allis C steering in reply to Richard G., 11-30-2005 06:52:56
remove the linkage between the gear box arms. then turn the steering wheel. if it turns then try moving the pedestal gear box. the shaft under the radiator can get real tight. bob
Richard G.
11-30-2005 18:35:08
Thanks,
I did pressure wash the tractor and water then paint may have run down the steering column. Maybe some PB Blaster will free it up.
Richard
jeffalex2
11-30-2005 17:27:23
The steering box actually has oil in it...sounds like some rust in the steering box worked it's way loose and may have bound the worm gear...or, possibly just some paint or water in another mechanical steering part that didn't set up until it got back home.
