WC that won't start
WC Dave
11-29-2005 17:06:26
Last weekend I got my 38' WC completely back together and attempted to pull start it, but had no success. I battled and battled making as many adjustments as possible and triple checked my timing but still had absolutely no luck. This WC has a freshly ground crankshaft, brand new pistons and sleeves, a magneto that was just gone through and repaired by Steve from New Jersey, that I must say has excellent spark, and a newly aquired freshly rebuilt carbuerator, I had spark, the fuel mixture seemed right, the engine was timed up, the machine was firing,but it was just like I was popping popcorn, it would fire a bunch, but it just wouldn't start up. I was truly perplexed and frustrated and am looking for anyone who might have some ideas for me. Could this be due to the fact that the valves are bad? Or maybe the camshaft, which ran the tractor fine before I had the magneto redone, is trully worn out? Any ideas would be greatly appreciated because I am really stuck on this one.
gene (missouri)
11-30-2005 20:25:11
 Re: WC that won't start in reply to WC Dave, 11-29-2005 17:06:26
Timing problem. Could be 180 out as the others suggested.
Or, the magneto is not properly timed to the engine. You might try a timing light to check the ignition timing. You need a 12 volt DC source, battery or battery charger to operate the timing light.
Gene
jeffalex2
11-29-2005 18:29:45
Yep, I'll bet you're 180 out too...remember, the motor is a 4 cycle so it hits TDC twice but fires on the comp stroke, you've got it firing with the exhaust valve open. When you check the timing, make sure you pull the #1 plug and put your finger over the hole and feel compression before you time the mag...
old
11-29-2005 17:32:25
I agree with BC sounds like your 180 out.
BCnT
11-29-2005 17:25:22
sounds like its out of time...180* out makes those exact noises...try swapping plug wires from one side to the other...example: if firing order is 1-2-3-4...swap 1-3 and 2-4 and try starting it again
