Coil - which side goes to distributor please?
gdtractor
11-28-2005 20:13:30
1950 AC B [with 1944 AC C engine.
Which side of the coil goes to the distributor, please?
The + side or - side?
Thanks
GD
old
11-28-2005 20:17:38
 Re: Coil - which side goes to distributor please? in reply to gdtractor, 11-28-2005 20:13:30
Which ever side that your battery ground is thats also the side of the coil that goes to ground, or in other words if its + ground + of the coil goes to the dist.
gdtractor
11-29-2005 02:01:17
 Re: Coil - which side goes to distributor please? in reply to old, 11-28-2005 20:17:38
The tractor is negative (-) ground. So I guess the - side of the coil goes to the distributor huh?
Will it run if hooked up the other way?
Thanks
GD
old
11-29-2005 07:01:56
 Re: Coil - which side goes to distributor please? in reply to gdtractor, 11-29-2005 02:01:17
Well as Sound says, yep it will run but not as well as if hooked up the correct way.
soundguy
11-29-2005 06:32:46
Yes.. with less sparkies..
Soundguy
