D10 questions
jerry l
11-27-2005 17:57:05
1960 D10 what voltage is the battery?? no tag on battery that can be read. also is #1 cyl in front of motor?? thanks for replys
steve(ill)
11-27-2005 18:05:52
 Re: D10 questions in reply to jerry l, 11-27-2005 17:57:05
#1 is up by the radiator. original battery was 12 volt positive ground. the nunmber of "fill" caps on the battery (cells) times two is the voltage. (6 caps or 6 holes is 12 volt). the voltage regulator determines the plus or minus ground. you can convert to negative ground like your truck normaly by putting on a new regulator or polarizing the old one (maybe)
jerry l
11-27-2005 20:41:13
 Re: D10 questions in reply to steve(ill), 11-27-2005 18:05:52
steve thats what i was thinking 12v but the old battery was a 6v but the tractor has been stored in a barn for 12 15 years so who knows who messed with it. i did check the LT bulbs and they were 6v ??
steve(ill)
11-28-2005 19:21:12
 Re: D10 questions in reply to jerry l, 11-27-2005 20:41:13
well i stand corrected. i knew the original D14 was a 6 volt, but thought all the other D series started as 12. My IT manual says the very very early D10 and 12 had 6 volt systems. It dont give a serial number, but leads you to believe there were very few built. You must have a low serial number.
