Hey Henry, so thats the D 15 you were talking about over on the other side. I have one too ya know. Anywho, if the ammeter is just stuck, you can still tell if shes charging or not. The battery voltage should be around 12.6 sitting there with the tractor NOT running, and then if the battery is good and the charging system is good and you fire the old girl up n give her some RPM, the battery voltage ought to rise to the 13 and a lil over 14 volt range. If it does that and/or the lights glow noticeably brighter from idle to wide open, shes charging okay. The VR's BAT terminal is wired to the battery to and through the ammeter which is like a short circuit therefore, its voltage ought to be nearly the same as on the battery. The gennys output is on its Armature post, but once it begins to gen (if it does???) thats then connected to the VR's BAT terminal via the internal Cutout Relay, so its voltage is near the same as on the VR's BAT terminal then and it should settle down fairly constant. However, with no load to control n stabilize the gennys output, the voltage on its Arm post could and would read higher until its tied to a load via the relay and eventually the battery. I dont trust a digital volt meter on some of this stuff so dont get too concerned unless the battery dotn stay up n needs recharged or the batterys voltage NEVER rises over 12.6 volts. Does the ammeter swing over to - discharge if not running n you turn on lights n ignition??? If an ammeter is good n works but it fluctuates too rapid n never seems to stabilize, the brushes may be worn down or the commutator is rough or the VR's contacts are burned or caboned up, but the type and price and qulaity of a voltmeter will determine how well it tracks n stabilizes and how stable it is. In other words if the battery voltage rises as I described and it stays up I wouldnt worry too much yet about wierd voltmeter readings yet. The 14.2 you described sounds fineeeee eee !!! Check for a tight belt,,,,, ,a good ground on BOTH the VR and the genny (an intermittent on ether can make the voltage fluctuate) ,,,,, ,good clean ammeter n VR n genny connections,,,,, ,,,,, check battery voltages setting n running as I described,,,,, ,,,,,see how she does, take 2 aspirins n call me Monday at the office. Take care Henry John T (your old JD buddy)
