WC bearing shim ?
slowsmoke
11-27-2005 14:48:36
swapping cranks in a wc. old crank was a couple thou. under, new crank unground. how much can I shim, vs. buying new bearings. Thanks, Don
slowsmoke
11-28-2005 07:59:41
 Re: WC bearing shim ? in reply to slowsmoke, 11-27-2005 14:48:36
Thanks guys. put all together, plasi gauge was .001/.0015, book says .002/.003,is this to tight, or should I buy new bearings? nothing is ever simple.Don
wdtom
11-29-2005 18:08:48
 Re: WC bearing shim ? in reply to slowsmoke, 11-28-2005 07:59:41
I won't answer your question becauseI don't know what will happen if you run it with .001 to .0015. I can say this, the clearance on a B engine is that, and it is only a little smaller on the bearings. If the crank is used and the bearings are used the unevenness of used parts in a different engine may wear into the proper clearance soon. Maybe if you decide to go with the somewhat tight clearances you could use a thinner oil for a while. 5-20 maybe, this would get in better than a 10-30 say. I would take it easy for a while too. My guess is you would be OK, but I would not want to tell you that and then you have trouble. Let us know what you decide and how it works out. Good luck!
wdtom
11-27-2005 17:29:33
You shim to maintain proper bearing crush. And to size the bearing. But to enlarge the bearing you would need to shim between the bearing shells, somewhat shaky I would say. Then you would have to increase the shim pack to maintain the proper crush which is .0015 on each side. I install the shells dry (always) and the bearing nearly dry and tighten the cap finger tight with no shims, then measure the gap between the cap and rod or block with feeler gauges, getting it even on each side. Then the shim pack is .0015 less than you measure. Then you put plasti gauge in and check what you have done. If it is OK then you lube the bearing and install the cap for the final time. If it isn't right you file the bearing shells a small amount. I check the bearing height by putting it ends down on a flat surface and running it under a dial indicator. When I have filed it the right amount I reduce the shim pack to maintain crush and try the plasti gaugh again.Takes a while. To increase the size of the bearing I would go for new bearings and take the time to fit them to the new crank.
Brian F. Williams
11-27-2005 15:24:54
I just put a new (to me) crank in a WD. I used new bearings and had to put in .010' in shims, if I remember correctly. They are available at NAPA. Hope this helps.
