PTO rear shaft case removal..
Mark/Ks
11-25-2005 09:23:31
Was wondering if I can remove the rear pto bearing case from the PTO housing, without removing the entire PTO housing unit.. I've got the PTO shaft off, and the 3 bolts holding the rear bearing case, but appears hung up someplace.. I need to fix a leak that is coming from the rear PTO bearing case Thanks...
orange-mud
11-25-2005 19:00:30
 Re: PTO rear shaft case removal.. in reply to Mark/Ks, 11-25-2005 09:23:31
I had this same problem on my WD-45 last year. I couldn"t get the bearing cage off without removing the PTO housing from the torque tube. I found it easier to work on after taking it off. Clean the bearing cage shims thoroughly (or buy new ones) before reinstalling cage to PTO housing. I used sealer between all shims and tightened the 3 bearing cage capscrews until i got the shaft to roll freely without end play or binding. Attach the PTO housing back onto the torque tube using a gasket with sealer on both sides...Worked like a champ for me!! Hasn"t leaked a drop in the past year!! GOOD LUCK!!
old
11-25-2005 09:36:23
Can't help with out knowing what your talking about. Sorry Allis made a lot of tractors and a lot of them come apart differant then others do and with out knowing what you have can't answer your question.
Mark/Ks
11-25-2005 11:00:56
 Re: PTO rear shaft case removal.. in reply to old, 11-25-2005 09:36:23
Sorry about that.. This is on a WD-45,, The PTO housing has a bearing case on the back side that is attached by 3 bolts.. Was wondering if the bearing case can be pulled off, without dropping the entire PTO housing... I've got the PTO shaft off now,, I don't want to drop he entire PTO housing if its not neceassary... Thanks...
