easy way to install rear wheel bearing in wd -45 a
eddie henderson
11-25-2005 08:27:03
i need to replace the rear wheel bearings in my wd 45. how many bearing per wheel does it have?
is this a big task?
thank eddie,
chester dubois
01-08-2006 20:44:31
 Re: easy way to install rear wheel bearing in wd - in reply to eddie henderson, 11-25-2005 08:27:03
IM Chet i replaced my wd 45 wheel bearings and seals its not that hard 1 block up the rear end so it wont fall over then take of the dust cap in the inside of the rear end off then take the bolt off dont loose the washers then u will see the bearings now take off the snap ring after that u hafe to slid out the rear axel shaft out or beat it out but make sure the gear dont fall and bust then u can replace the bearings and seals good luck !!
JMS/MN
11-25-2005 18:34:06
Are you talking about the lower unit- where the wheel center mounts? You need to drain the final drive, take off the lower cover, and you will be working upside down, snap rings involved, bearings on each end of the shaft. (NO shaft will be supported by only one bearing!). You need a parts manual to ID all of the parts. Small place to work in.
wdtom
11-25-2005 12:33:38
You need a copy of the factory manual. Basically you take the axle out by taking the adjustment nut off of the inside, it is under the sheetmatal cap. You need to set the clearance/bearing play when you reassemble.
eddie henderson
11-26-2005 16:14:29
 Re: easy way to install rear wheel bearing in wd - in reply to wdtom, 11-25-2005 12:33:38
thank for all the info,it was very helpful,
i got my wheel bearing,out now iam ready to put in new ones,thank again guys,i could not have done it with out your help.
thank you
eddie-h
