tractor pulling with gleaner
BURGE
11-24-2005 19:56:08
i heard you can put a gleaner combin engine in a wc 0r wd allis and make one bad out fit,so i have 2 wc waiting to become one good pulling tractor but i need to know what gleaner engine needs to be in there can any one help
old
11-24-2005 20:06:12
 Re: tractor pulling with gleaner in reply to BURGE, 11-24-2005 19:56:08
You should have been watching RFD TV to night they had a WC with a 6 cylinder combine engine in it. They said it was from a gleaner
JBF
11-25-2005 06:13:20
 Re: tractor pulling with gleaner in reply to old, 11-24-2005 20:06:12
A motor from a glearner E combine will fit right in. That motor is pretty much the same as a D17. They have a bit more power than the WC engine, just make sure to use the tracot governor because the gleaner combine were set to idle or run wide open there is no in between. This make a pretty potent little puling tractor combination. Good luck!
