Transmission/differential fluids model CA
Neil1
11-22-2005 09:25:06
I Have a 1949 model c or ca (not sure which). I would like to know what I should use for the transmission and differrential oil/grease. Should I use the 80-90 Wt. gear oil for just 30Wt. engine oil. Also the hydraulic lift unit What do I need to refill this with oil/grease?
Any help would be appreciated.
Thanks, Neil
Dick L
11-22-2005 10:54:00
 Re: Transmission/differential fluids model CA in reply to Neil1, 11-22-2005 09:25:06
They both call for 30 wt oil and it covers all there. The differential, transmission, and hydraulic system. You can use the newer hydraulic oils as well.
Texas Denny
11-22-2005 14:29:41
 Re: Transmission/differential fluids model CAdiffe in reply to Dick L, 11-22-2005 10:54:00
Dick is correct. Remember that if you use 30W motor oil, it must be Non-Detergent. The oil for the differential, transmission, and hydraulic system is all the same - one reservoir for all.
If you have a 4 speed forward transmission, you have a CA. If it is a three speed forward, it is a C.
steve(ill)
11-22-2005 18:09:25
 Re: Transmission/differential fluids model CAdiffe in reply to Texas Denny, 11-22-2005 14:29:41
original was 20 wt motor oil. these days most use universal trans-hydraulic fluid. it is specifically for anti- foam and water dispersant. more of a 10 wt oil. buy at farm store or wall mart.
