CA Carburetor
John in KS
11-19-2005 18:19:31
I have a CA I'm getting ready to sell and I wanted to get it running smooth for the next owner. I rebuilt the carb and put it back on and when I turned the fuel on it leaked. Yesterday I took it off again and checked the float, put on another gasket and then put it back on the tractor. This time when I turned on the fuel there was no leak and it worked fine. There was a little poping going on that I figured was the points, condensor, or plugs so I changed those today and when I turned on the fuel the carb leaked. It sounds good and is running smooth. I know I can just turn off the fuel and let it run itseld dry, but I hate to do that since this tractor is in darn near perfect shape. Any ideas?
old
11-19-2005 18:38:55
 Re: CA Carburetor in reply to John in KS, 11-19-2005 18:19:31
Couple things it could be. First the needle seat may not be tight enough. Or if it has one of those new rubber tipped needles its just not seating. To fix that you open it back up and pull the float, the drop the needle in to the seat and tap on the needle with a small hammer or the like. You don't need to tap very hard just enough to set the end of the needle.
John in KS
11-19-2005 18:51:33
 Re: CA Carburetor in reply to old, 11-19-2005 18:38:55
I've heard that before so when I had it apart the second time I tapped on it. Maybe I should have tapped harder.
old
11-19-2005 18:56:17
 Re: CA Carburetor in reply to John in KS, 11-19-2005 18:51:33
Maybe also double check the seat and make sure its good and tight. I know sometimes because it takes a wide screw driver its hard to get them as tight as they need to be.
John in KS
11-19-2005 19:14:41
 Re: CA Carburetor in reply to old, 11-19-2005 18:56:17
I know what your saying. I don't own a screwdriver wide enough for the seats so I've always used a stiff putty knife. Has worked in the past, but maybe not this time. Just can't figure out why there was no leaking yesterday and then today it leaked. Never had this problem before and I really hate having to take it off again, but guess I will - at least one more time. Thanks old for the help. Oh thought I'd ask. You know why I'm getting this freeload link at the bottom of my posts? I know less about computers than I do carbs and can't figure out why it shows up. When I post the message there is nothing in the link bars.
old
11-19-2005 19:42:24
 Re: CA Carburetor in reply to John in KS, 11-19-2005 19:14:41
That I have no idea about its just one of those free loaders. As far as your leak you may have picked up a little junk from the gas tank or line and that maybe the problem also.
John in Kansas
11-19-2005 20:01:33
 Re: CA Carburetor in reply to old, 11-19-2005 19:42:24
I sure hope not, but maybe. Hopefully I'll get to it tomorrow evening. I'll take it off and clean it up and blow it out again. Maybe even drain the fuel tank and clean the sediment bowl. Thanks again.
BCnT
11-20-2005 07:03:50
 about that link... in reply to John in Kansas, 11-19-2005 20:01:33
its spyware...go here and make sure you dont have any viruses and then poke around on website...they have tools to help get rid of the spyware...and just because you have norton or maccafee doesnt mean youre not infected.
