WD45 hyd.
vinnie
11-17-2005 08:54:18
I got a WD45 now and want to know if the hyd on it will power a log splitter and if it will how do you set it up?
vinnie
11-18-2005 16:55:58
 Re: WD45 hyd. in reply to vinnie, 11-17-2005 08:54:18
BCnT --Send me your pic.of your setup [email protected]
CAL (KS)
11-17-2005 18:34:06
go here.. has pictures and some description of a pretty simple setup for double acting cylinders on wd45 with factory hyd pump
Link
a pressure release valve or bypass whatever you wanna call it will remedy the excessive high pressures put out by this style of hyd pump
as others have said.. the larger the cylinder the slower it will go
JMS/MN
11-17-2005 16:41:18
The integral system in a WD45 is a high pressure system that runs about 3200psi. It is low volume, high pressure system. The pump provides pressure, but it can be plumbed to make it a two-way system, as long as you add a two-way valve and a return line to the tractor reservoir- same with any other hydraulic pump. Nothing mysterious about that. You are not limited to any specific diameter of a cylinder. Just need to remember that the bigger the diameter (as long as it can withstand the pressure)- the slower the cylinder moves- not because of pressure, but because of pump volume (ie, gallons per minute)- the slower the cylinder moves. To hook your tractor to a log splitter- make sure the cylinder will withstand 3200+ lbs pressure, install a two-way valve with a return line bringing the oil back to the tractor reservoir (back into the fill opening works), and forget the mickeymouse return spring stuff with a one-way system. Actually, I think it is more economical to run a splitter with 10 or so hp engine instead of running the 40 hp tractor engine. But the AC would work fine if you it up right.
Punchie
11-18-2005 04:36:13
 Re: WD45 hyd. in reply to JMS/MN, 11-17-2005 16:41:18
Yes will cost you about .75 gallons of gas per hour of spilting. If you can use a maul on the easy rounds and the spliter on the other ones.
Teddy
Zonie
11-17-2005 15:24:01
The WD and WD-45 hydraulic stsem is a high pressure/ low volume system. Unless you have a cylinder rated for pressure of 4500 psi and low volume like a 2" diameter piston you are asking for problems. with a large diameter cylinder the spliter will be really slow and you will not have enough oil to extend the ram fully. You just might be lucky and be able to get away with it but it will function slowly.
BCnT
11-17-2005 09:52:58
i got no doubt hydraulics are strong enuff...you would have to set the cyl on log splitter up for single action and mount some springs to return cyl ram.
Texas Denny
11-17-2005 12:05:33
 Re: WD45 hyd. in reply to BCnT, 11-17-2005 09:52:58
BCnT, couldn't you tap into one of the two cylinder lines with a 3 way valve and plumb the return from the three way back to the hydraulic sump. The lift lever would have to be up all the time. It seems to me I heard of someone doing that. Wonder if such a getup would be hard on the relief valve. The simplest way is to use springs as you describe. It is simple and inexpensive. Good advice.
BCnT
11-17-2005 16:20:07
 Re: WD45 hyd. in reply to Texas Denny, 11-17-2005 12:05:33
Denny,
my D17 is plumbed for a 2 way cyl on loader dump but it was like that when i bought the tractor...with a dollar and my knowlege of hydraulics you MITE get a cup of coffee.
i was thinking of building a splitter and was gonna go 1 way just to speed things up
chuck
Texas Denny
11-17-2005 18:02:33
 Re: WD45 hyd. in reply to BCnT, 11-17-2005 16:20:07
I've never done this on an Allis. But that is the way that two way hydraulics work on a wood splitter or a front end loader or whatever. I just don't know enough about Allis to know if there would be an issue. One thing for sure is that I don't know where you could return to the sump other than the fill tube. I think that would be unsatisfactory. I probably won't ever figure this out myself because I don't have a need for a solution. I've got two tractors with two way right now (unfortunately, neither is Allis).
BCnT
11-17-2005 19:46:06
 Re: WD45 hyd. in reply to Texas Denny, 11-17-2005 18:02:33
you want a pic of how mines set up on the 17??? i cant 'splain it but i can take pitchers ;)
send me a e...i dont know if i still got yer addy or not
