Differential Carrier Assembly (Allis WC)
Pat Livingston
11-17-2005 08:12:14
This question pertains to the differential carrier assembly. Does anyone know of a way to stop a small leak without putting in a new gasket? Or any suggestions on how to try to stop it? Any advice will be very appreciated. Thank You -
Zonie
11-17-2005 15:31:20
 Re: Differential Carrier Assembly (Allis WC) in reply to Pat Livingston , 11-17-2005 08:12:14
If it is a gasket leaking you pretty much need to replace the gasket to stop the leak. Youcan always buy new gasket material and make a gasket if you can't find the proper gasket.
Texas Denny
11-17-2005 12:09:42
If you know where it is leaking exactly, you could try JB Weld on the seam. Drain the differential and clean it thoroughly and get it dry, free of oil and solvents. It might work.
It makes me wonder why it is leaking. I wonder if you have a crack in the case. Thorough cleaning should uncover the source of the leak.
