CA Question
mike732
11-16-2005 18:23:29
I just traded for a CA with a wide front end,it runs good but the steering is reversed you have to turn right to go left and so on, how do I repair it?
Dakota Dave
11-16-2005 18:36:49
 Re: CA Question in reply to mike732, 11-16-2005 18:23:29
Sounds like you have a "B" front end on a CA. Does the Drag link go directly to the axle or to the steering pedestal under the radaitor?
mike732
11-16-2005 18:40:58
 Re: CA Question in reply to Dakota Dave, 11-16-2005 18:36:49
I"m not sure, I"m home now and it"s at the farm, if it is a B front end can it be fixed?
steve(ill)
11-16-2005 18:54:24
 Re: CA Question in reply to mike732, 11-16-2005 18:40:58
a B wide front looks like a wishbone or "hump". a wide front for a CA is made of a steel box tube arrangement and is adjustable. the sides slide into the center section. I would guess you have the wishbone B axle on an old narow front CA.---- the CA has a steering box under the gas tank with the arm pointed UP, the rod goes to a second gear box under the radiator on the pivot pedistol.--- the B has the gear box under the gas tank with the arm "down". the rod goes to the front left wheel kingpin and steers the wheel directly. no second gear box. you can change the rear gear box to a B, or modifiy the present gear box arm to point down.
mike732
11-16-2005 18:58:57
 Re: CA Question in reply to steve(ill), 11-16-2005 18:54:24
Later B's had the square adj. axle also.
steve(ill)
11-18-2005 20:02:59
 Re: CA Question in reply to mike732, 11-16-2005 18:58:57
B adjustable was similar design, but not the same. also the B steering rod goes to the wheel, C and CA go under the radiator support.
mike732
11-19-2005 05:14:51
 Re: CA Question in reply to steve(ill), 11-18-2005 20:02:59
You were right, it is a adjustable B front end. Now for the fix i'm going to try to reverse the steering arm on the box to the down position.
