Snap Coupler Drawbar support will not come off. Wh
XFarmer Brown
11-16-2005 16:05:31
I purchased my uncle's WD45 last year and recently tried to take the drawbar off in order to hook up my snap coupler plow. To my suprise, the U shaped support that holds the drawbar up is not notched out at the upper end like my others. Since the stud for the castle nut is welded in the angle, I would have to take the bolts out of the bottom of the diff case in order to put my plow on. What's the deal ?? I gave up and put my plow on my D14.
Is this some kind of HD or early version or a special version for those paranoid that their drawbar would fall off? It has not been welded shut, it looks like it is a factory part.
Zonie
11-17-2005 15:43:24
 Re: Snap Coupler Drawbar support will not come off in reply to XFarmer Brown, 11-16-2005 16:05:31
I have a '54WD that was made after the WD-45's started into production it had the pin hitch and the bail was just as you described yours, how ever someone had cut the draw bar like others have mentioned below it works good like it is. and I have converted this tractor to a snap coupler system.
Just be sure to replace the Castle nuts after you get the bail off. the bail gets it's side strenght from those nuts.
Tramway Guy
11-17-2005 07:26:57
Are you sure it is a WD45? Maybe it is a WD which was converted to Snap-coupler; and they didn't bother to change the bail.
XFarmer Brown
11-17-2005 08:15:39
 Re: Snap Coupler Drawbar support will not come off in reply to Tramway Guy, 11-17-2005 07:26:57
Yes, it is definitely a 45. Apparently the bail got replaced by an older one.
Texas Denny
11-17-2005 07:02:40
I've read all the responses. You said this was a WD-45 so I was trapped in that mode. No WD-45's came from the factory as you describe. I've not seen many WD's without the Snap Coupler system so can't remember what it looks like. Your drawbar is probably from an early WD. Den/SouthernIllinois has the logical solution if it bothers you. If the cutting is rough, which it will be, use a hand grinder to smooth it out. If you have access to a big drop saw, it could be cut. Or it can be done on a vertical mill also.
And, I recall someone taking issue with the term "Snap Coupler" claiming it was not an Allis Chalmers term. It actually was an Allis Chalmers term and was copyrighted by them. It appears in lots of ads from the early 50's.
Tramway Guy
11-16-2005 20:05:17
It doesn't have to come off. Our '49 WD (when I was in my youth) had the 'pin type' connector, and the exact same bail that you describe. It did not have to come off...only the drawbar itself. It was swung all the way forward (or back, I don't remember), pinned in place and it was good to go. I do remember the first time we mounted it, we were concerned that the PTO would get hit by the plow's drawbar, but was no problem there, either.
oliver fan
11-16-2005 17:36:08
Xfarmer, To mount a plow on a WD with out Snap Coupler you would take the drawbar off and then take the two pins out of the U bracket and swing the U bracket around foward and re-insert the pins. This put the bracket out of the way for the plow pull point to hook up where the drawbar was. You might look and see if that will work on your snap coupler plow.
Hope this helps.
CHALMERSBOB
11-16-2005 17:26:09
THE EARLY WD LIFT PLOWS WERE MOUNTED TO THE DRAWBAR. THEREFORE IT DIDN'T NEED TO COME OFF. BOB
XFarmer Brown
11-17-2005 08:22:40
 Re: Snap Coupler Drawbar support will not come off in reply to CHALMERSBOB, 11-16-2005 17:26:09
Ah Yes. Now the memory comes back. The old pull plow and planter had a "tongue" that was sort of H beam shaped. The drawbar laid in that with a cross pin to keep it on. The "mounted" implement was still pulled by the drawbar.
thanks
Den/Southern Illinois
11-16-2005 16:35:05
Before there was a snap coupler system...there was the pin type drawbar. On the pin type system...the drawbar support was not notched to be removed. I have one that was never cut from the old pin hitch days. I would say that is what someone put on your tractor. A possible solution is to remove the brackets from the bottom of the diff case, unbolt the drawbar support from the brackets and get someone to do a nice job of cutting the ends straight out the same width as the holes. After this is done...it will be the same as the support that was used with the snap coupler system. Den
XFarmer Brown
11-16-2005 17:05:53
 Re: Snap Coupler Drawbar support will not come off in reply to Den/Southern Illinois, 11-16-2005 16:35:05
thanks Den ! We had a '49 with the pin hitch and we had a pin hitch plow and planter . I do not remember the support did not come off, but it makes sense. That was too long ago for me to remember.
My uncle never had any snap coupler equipment, so it was not a problem for him. Ok, so I will have to torch it out and grind it smooth or find a new style one in good condition.
Thanks again for the history lesson.
den/southern illinois
11-16-2005 18:38:38
 Re: Snap Coupler Drawbar support will not come off in reply to XFarmer Brown, 11-16-2005 17:05:53
You can tourch it if you want but if you take the brackets off the dif and unbolt the castle nuts...you can then cut out the ends and use the same support without buying a different one. And I have a good different one for sale...but still hate to see you have to buy one when you can make the one work that you have. Den
XFarmer Brown
11-17-2005 07:55:44
 Re: Snap Coupler Drawbar support will not come off in reply to den/southern illinois, 11-16-2005 18:38:38
Yes, That's what I meant by torch it out, to take it off and cut the end of the hole out so I could reuse it.
How much do youwant for the one you want to sell ?
Texas Denny
11-16-2005 16:30:34
Looks like one for the books. I've never heard of this either. I wonder how they ever got it together. It seems to me that the cross bar would have to be welded in place.
JMS/MN
11-16-2005 19:37:46
 Re: Snap Coupler Drawbar support will not come off in reply to Texas Denny, 11-16-2005 16:30:34
They got it in place by doing in reverse order what other posters said to take it off. Remove the mounting brackets, bolt onto the 'bail' (correct term for that piece), and rebolt it to the tractor. Personally,I've never run across that either.
