Denny, while we may have a friendly disagreement concerning the 6 n 12 volt coil construction, it sounds like were on the same page on this one. I agree to get 12 volts from a 6 volt genny by using a 12 volt VR the Field current has to be increased, and the reason why I think theres not too much of a problem is since youre only dealing with a few amps in the first place, even if doubled theres no dramatic heat increase and the field windings DC voltage withstand is way way above 6 or even 12 volts anyway. It seems the commutator bar spacing may be different on a standard 6 n 12 volt genny armature??? but it still works regardless. We may have to ask Ken of Kenneths Classic Generator down in Texas to provide the fine details??? Regarding a Class B (supplies Voltage to a grounded Field) versus a Class A (supplies a ground for Field) Voltage Regulator substitution, I reckon so long as it were rewired so you use the relay action to supply the contrary, it will work in theory HOWEVER that relay action and cycling and how much resistance it uses or switches may or may not still do the proper job when its modified?? Theres field current modulation (relay action)going on to achieve a more precise regulation (net effectice field current over time) besides just switching in a bias or a dead ground as an old fellow engineering buddy Gerald instructed me on some time back. I guess its one of those things to just try n see and add or subtract ballast if necessary cuz Im not in the mood to work out all the engineering details. I AGREE IN THEORY IT CAN BE MADE TO WORK but thats all the further Im willin to stick my neck out yet lol As I originally posted, the DC VR cant be used as an alternator regulating device absent modification, so I have a question for ya if you did that: Did you use the Field current control relay to cycle or ballast the current into the rotor via the slip rings or did you modify n regulate the AC Stator output or the rectification or what????? The good SoundGuy seems to have a good grasp on the Ford Class B systems, anxious to get any comments from him. I like to tinker n jury rig myself, prob why we usually thuink similar on these sparky projects lol Before I forget, I didnt see nor did my manual provide much insight into where to add n fill n check the oil in my AC D 15 as far as the power steering????? I take it the hydraulic pump n pedestal n gears all work and are lubed by the same common fluid?? but Im unsure where to check or drain or add it???? John T
