WD/WC engine swap???
Jim in Michigan
11-14-2005 04:51:14
We have a old Wd for parts and a WC with a bad engine,,will the WD engine go onto the WC? what all has to be changed to make it work? Thanks,,,Jim
Zonie
11-15-2005 11:13:54
 Re: WD/WC engine swap??? in reply to Jim in Michigan, 11-14-2005 04:51:14
The WD and WC engines are basicly the same engine. they will interchange with no problem. The D-17 or E gleaner engine will also fit with some slight modifcations. If it were me I'd fix up the WD instead of the WC, the WD is a much more usable tractor. It has live hydraulics and PTO and you can get a 3 point conversion for it.
you can even find powersteering for it if you look hard enough.
J.C. IN AZ.
11-14-2005 12:15:10
Your contimplated swap is one like I did once. I bought a WD 45 Diesel and the Engine went bad. I had a Wd with a good Engine and not much else so I swapped the WD Engine into the WD45D. used the WD Hood ETC. and ended up with a good useable Tractor from the two. At Sale time some sharp eyed lookers spotted the Side Plate right away and as I had nothing to hide I explained the circumstances.
old
11-14-2005 07:13:13
The diferance in a WD and WC tractors are the engines but used the same engine but differant trannys/rear ends Even a lot of sheet metal will swap between them.
JMS/MN
11-14-2005 07:05:30
They both used the same 201 inch block. Bolts right in. 45 engine or E Gleaner engine fits too.
cbp
11-14-2005 05:19:42
Someone asked a question last week on the WC casting numbers and I looked in the Tractor Registry just to see if there were some clues there. At the time I noticed that people had WC serial numbers and WD and WD-45 engine or casting numbers listed which made me wonder if they'd done a swap or were mixed up on what they had. When I was very active I always thought they should swap but never had one to try. As with RC (mixture B/C and WC), it seemed like bell housings and shaft lengths all the way to the D-14 and perhaps the 10/12/15 would be similar enough to mix and match. Certainly worth the research and it would not be that difficult if everything lined up. I have fresh B engine and a shot D-14 engine with a D-14 waiting for one, maybe I'll do some measurements on that and see if that would be a realistic swap. It would be like creating a modern version of the underpowered RC. Really a trip since this D-14 is a dually. Since you have both WD/WC there, it shouldn't take but a couple of hours to figure out if the basics line up. Linkage and wiring is not really an issue.
