Stuck Rear Wheels - Allis CA
Mike in NC
11-13-2005 18:33:15
I have a 1950 CA I am restoring, but I can't get the rear wheels to come off the hub. I gave up on removing the rims using the adjustable rails, but it seems the whole wheel ought to be easier to remove. I guess they must be rusted right onto the hub. Any suggestions?
Dick L
11-14-2005 17:56:01
 Re: Stuck Rear Wheels - Allis CA in reply to Mike in NC, 11-13-2005 18:33:15
I have done what old said with all brands. Just loosen the bolts a bit and I crank the front wheels to turn sharp on my cement drive and give the brake quick hit every little bit and then turn the opposite direction with the same action. Depends how bad it is rusted in how many circles you have to make.
Tyler from Utah
11-13-2005 21:40:59
You can do what Old has told you or you can jack it up and take a sledge hammer and hit it on the bottom on the side of the tire. Dont worry it wont hurt them just dont let it fall off the jack! We had the same problem with or 1952 put some anti sieze on the studs are's were about welded in!! Good luck! Tyler
old
11-13-2005 19:08:37
If it runs just loosen all the bolt on one side just a little and drive it around and watch for it to pop loose. Then retighten them just a little and do the same thing on the other side. Just don't tighten them back up to hard or you might be back to square one again.
XFarmer Brown
11-15-2005 15:05:36
 Re: Stuck Rear Wheels - Allis CA in reply to old, 11-13-2005 19:08:37
I have gotten WD wheel off using a puller I rigged up using a block of wood on the axle end under a Ford style 3 point hitch style drawbar with bolts through the drawbar and the wheel weight holes. The bolts have to be square neck (carriage bolts)with the heads inside the wheel and the nuts out on the drawbar strap. The drawbar was the type that is basically a big strap with a row of holes all along it's length. The bolts pull on the wheel while the wood block pushes against the axle. I did have to tighten, soak with penetrating oil, come back later and retighten several times before it popped off. This method could be used in conjunction with the others listed previously.
