Alternator conversion
dean sahs
11-11-2005 17:49:31
Have a model C Allis Chalmers tractor which had all electrics removed. I would like to install a simple three wire alternator to charge a 12 volt battery, no lights, but would like to install a voltage gauge. Can any one tell me how to wire this setup. Thanks , dean
Steve in N.J.
11-14-2005 06:17:04
 Re: Alternator conversion in reply to dean sahs, 11-11-2005 17:49:31
Dean,
We offer quite a few different 12V conversions for AC tractors. Drop us a line, be happy to help you out with any info or one of our conversion kits if interested.
Steve@B&B
Rod (NH)
11-11-2005 19:10:59
Hi Dean,
I assume you have a magneto ignition. If so, you can check out how I converted my '42B. A C should be the same except for a possible clearance problem between the Delco 10SI and the C steering linkage. I understand that a newer version of the Delco has a smaller diameter and is better suited for a C. I don't know the model number. If Steve from B&B Custom Circuits sees your post, I am sure he can help you out also.
third party image Rod
steve(ill)
11-11-2005 19:52:14
 Re: Alternator conversion in reply to Rod (NH), 11-11-2005 19:10:59
the newere DELCO is CS 130
cbp
11-11-2005 18:44:59
Check out this thread from the N-Board. It's way more than you want to know but it looks like they covered it pretty thoroughly.
Link
