Problum with D14 governor
William Peets
11-11-2005 14:10:24
The existing front bushing on the governor is to large for the shaft about 1/16" play but shows now signs of wear. The shaft also shows no signs of wear. I ordered a new bushing part # 207714 which is the same size as the existing bushing about 1/16" to large. The governor shaft is cut down in the front which goes into the bushing. The picture in the parts manual shows the shaft to be cut down. I need some help.
cbp
11-11-2005 18:31:55
 Re: Problum with D14 governor in reply to William Peets, 11-11-2005 14:10:24
Your saying that the shaft is 1/16 inch too small to fit into the bushing? I have one apart in the shop and can take some measurements if that's it?
William Peets
11-12-2005 01:31:53
 Re: Problum with D14 governor in reply to cbp, 11-11-2005 18:31:55
Yes the shaft is to small or it is the incorrect bushing. Is your shaft cut down where it inserts into the front bushing. The new bushing ID is 7/16". I had the governor off and the cut down portion of the shaft is about 1/4". I thought the previous owner may have installed the incorrect bushing. Under a load the governor does not seem to open. I want to use the tractor in antique tractor pulling it should do quite well once the governor is correct. I tried it this year and it would bog down almost to idle. My wife says I pull like a snail. She pulls with a 435 John Deere. I like the feel and the way the Allis handles its a great tractor.
cbp
11-12-2005 20:43:30
 Re: Problum with D14 governor in reply to William Peets, 11-12-2005 01:31:53
I'm sorry I didn't check the board earlier. I will look at it tomorrow. The bushing should be easy to get if that's the problem. If nothing else a machine shop will fix you up in no time. I'd be worried that some damage may have occurred from running it that way that will wear the new bushing quick. I'll make a note to go out as soon as it's light.
William Peets
11-13-2005 01:26:45
 Re: Problum with D14 governor in reply to cbp, 11-12-2005 20:43:30
I have had the tractor for quite some time 8 to 10 years it does not seem to have caused any damage. It is in excellent shape. It works fine around the property it just does not keep the RPM up under a extremely heavy load. I brought it to a machine shop and he wanted me to try and find the correct part.
cbp
11-13-2005 17:10:48
 Re: Problum with D14 governor in reply to William Peets, 11-13-2005 01:26:45
I put a mic on it and the end, which is turned down, was 3/8s. It was extremely scored up. This is not my good machine. The bushing looked to be just a hair bigger but I couldn't get the inside mic down in there.
It was usually easy to go to a machine shop and find stock that would work for that type of thing. If the end on yours is anything like mine, it might be good to have them clean up the shaft. I don't think I'd put it together so scored up.
William Peets
11-14-2005 14:34:38
 Re: Problum with D14 governor in reply to cbp, 11-13-2005 17:10:48
Guess I will have to try the machine shop thing again. I would think that bushing would be available if I had the correct part number. The part number in the parts book must be incorrect the bushing they sent me is way to large.
