Bearings for Ross Steering Unit - 1942 B
Whiskers1949
11-10-2005 18:02:21
Are the upper and lower shaft roller bearings the same? I found only balls on the lower side and perhaps some fragments of a cage. Anybody know a number (i.e. Timken) for these? At the upper end of the tube near the steering wheel, what kind of bushing/bearing goes there? Have ordered manuals, but not here yet.
Jerry Coulter
11-10-2005 19:36:10
 Re: Bearings for Ross Steering Unit - 1942 B in reply to Whiskers1949, 11-10-2005 18:02:21
The Ross gear takes 20 steel bearing balls, 10 above and 10 below the worm. I find nothing about a cage in the parts book.
Whiskers1949
11-10-2005 20:35:59
 Re: Bearings for Ross Steering Unit - 1942 B in reply to Jerry Coulter, 11-10-2005 19:36:10
Well, there were about 10 loose balls in the lower end, along with a lot of rust, the ball cup and solidified lube of some kind, but the upper bearing is intact..... ten balls held in a "cage"..... like the old 55 Chevy wheel bearings. The upper bearing is held in place by a snap ring. In looking at the diagram referred to in another thread, I do not see an upper bearing shown.
Whiskers1949
11-11-2005 12:06:17
 Re: Bearings for Ross Steering Unit - 1942 B in reply to Whiskers1949, 11-10-2005 20:35:59
Errr..... know a good recipe for crow pie? On closer inspection.....upper just like lower. After taking all the gunk away.....a cup and 10 or so balls.
steve(ill)
11-10-2005 18:32:11
the upper tube bushing can be made on a local lathe in a few minutes. turn a brass bushing that will just slip into the tube, hole in inside that has .010 clearance to the shaft. push the bushing into the tube 1 inch and stake from the outside with a center punch in 3 spots.
