WD 45 Torque settings
Hendrik W Alber
11-09-2005 20:10:36
Does anybody have the head torque settings for a WD 45?
Thanks
Hendrik W Alberts
11-11-2005 15:23:51
 Re: WD 45 Torque settings in reply to Hendrik W Alberts, 11-09-2005 20:10:36
Thanks
BushogPapa
11-10-2005 05:31:22
I think it may be normal for the gasket to seep at first on the pushrod side.. I usually have to try 2 or 3 times and make new gaskets for the plate that covers the top rear water outlet that is not used....it is held in place by 2 head bolts and they crush the gasket pretty bad.. I always thought that finding a top water outlet from a WC would be better as it uses Both water outlets...!!! Ron..
BushogPapa
11-10-2005 05:30:59
Texas Denny
11-09-2005 20:39:39
My book says 70 ft# on the 1/2 studs and 25 ft# on the 3/8 studs. I've used these numbers on a half dozen rebuilds and never had a problem. After you get it running, you need to bring it to operating temperature and pull the valve train and torque all the studs a second time. First, torque to about 75% of the spec level starting at center and work way out. Then go back and torque to spec starting at center and working your way out.
