Tranmission cooler for newer Allis
cbp
11-08-2005 17:23:14
I have given up on trying to get my AC 816 Backhoe transmission radiator replaced or repaired. They are pretty crucial to running when you shuttle a lot (the shuttle transmission starts smoking it gets so hot). It's a high pressure system of course and sits up front of the coolant radiator behind the grill. Perkins dealers suggested daisy-chaining boat coolers but they are way different. This shares some drive train with the 170 diesel and if anyone knows whether that or similar vintage machines with shuttle have a skookum cooler, let me know. I need to find something or I can't move much dirt with it. Any ideas are welcome (e.g., Allison coolers etc). They have to be small with a lot of surface area. The original is about 2 by 1 and 2 inches thick fins. I don't mind fabricating the mounts.
Hurst
11-09-2005 14:19:32
 Re: Tranmission cooler for newer Allis in reply to cbp, 11-08-2005 17:23:14
My 7000 allis has a tranny hydraulic combo cooler that is about 1ftx2ftx2in. It was replaced in 1991 I think is the date on it (I just bought the tractor), so it should be pretty easy to find at a dealer. I don't have the tractor where I can measure it and wont be near it for about 2 weeks. I would look at a 7000 near you (mine is a black belly, but redbelly should be the same or really close). Also, may try looking at a 190xt or 200, they should have a similar cooler as they have a similar hydraulic set up. Hope this helps. Maybe someone can take a pic of theirs and post it, I would if I was not at school. Good luck
Hurst
856 puller
11-09-2005 13:30:39
i used a cooler off a jd planter one time and it worked good. its small and built heavy. there on the vacume type
Gatz
11-08-2005 19:12:55
Aren't these coolers on the return side of the pump or filter (meaning minimal pressure) ?
You might try Northern Hydraulics, or Surplus Center.
Or, look into an automotive/truck type automatic transmission cooler. Even a combine oil cooler might work.
Gatz
cbp
11-09-2005 04:33:18
 Re: Tranmission cooler for newer Allis in reply to Gatz, 11-08-2005 19:12:55
Yes, you are right, it can make a nice horizontal fountain of pink but its not true high pressure. The truck idea might be the best as far as availability but I'm not that familiar with their size. I figured I'd better try to get it in the grill shell so the fan could do it's magic (plus the protection aspects). Spose I could call Frieghtliner and see what they put on theirs. I 've got a service center northeast of me. Thanks.
BCnT
11-09-2005 09:42:47
 Re: Tranmission cooler for newer Allis in reply to cbp, 11-09-2005 04:33:18
i've used air conditioning coils off cars for oil coolers on race cars before...used em on oil and tranny...should work fine on your tractor and LOTS of capacity.
cbp
11-12-2005 20:46:36
 Re: Tranmission cooler for newer Allis in reply to BCnT, 11-09-2005 09:42:47
I hadn't even thought of that because of the width. I suppose they could be mounted sideways though. That would be a simple and cheap fix. Thanks.
