If Your Going To Rebuild
Dick L
11-08-2005 12:50:28
If you are going to rebuild your carburetor and you do not have a drawing you might want to print the one below.
Nine times out of ten you will find the leak thru your carburetor having to do with the float valve. Most of the time it will be a speck of rust or such. I have not had good luck with the rubber/plastic tipped float valves in the past. I have rebuilt a few in the near past that worked out but back eight or nine years ago I had over half fail. I save every thing that I take out if it looks like there mignt be any use left in what ever it is. The ones that failed I replaced with used, redressed solid brass float valves. The last rebuild kit I purchased had a solid steel float valve. For tractors that set a lot I am not sold on the steel float valves ether, but it did not leak. A drop of water standing at the tip will start its own supply of rust.
third party image
