restoration on a WD
Guyzoo
11-07-2005 17:50:14
Hi, I just finished taking my old WD apart. Now it is All in piece. My Question is: how can I clean the inside of all the housings like engine block, differential case etc. My other question is how do I prepare the metal surface for primer after I have removed all the old rust and paint with a angle grinder and a wire cup. It still have a grease residue.
THANKS TO ALL
JMS/MN
11-07-2005 21:36:33
 Re: restoration on a WD in reply to Guyzoo, 11-07-2005 17:50:14
5-10 gallons of solvent with an air gun should do the entire tractor.
Gatz
11-07-2005 19:02:42
For getting the insides of castings clean, check with your local automotive engine rebuilders.
The local CarQuest store has one of those high-pressure hot-water machines (Wheel-a-Brator?) that does a terrific job. You'll need to remove all plugs, bearings, fittings, etc beforehand.
I read somewhere that zinc-chromate paint is good for painting insides of castings where there may be a problem of seepage from light oils.
Last week I bought some Cold Galvanized paint that is soemthing like 95% zinc particlates. They said it should work good. Gatz
mace56
11-07-2005 17:56:06
I use the 'paint and bodywork' forum for that kind of info. They have some real good guys that watch that forum. Inside the castings? WOW I love WDs to look at, but for now I just have a B. My garage and tools are too small.
