Finding a production year
Butch W
11-07-2005 14:20:40
I have bought a WD at auction,I can't find a serial #,I looked this thing over really good and found alot of part # on pedals and differential all begin with AM, differential #am 3644-5 ,The engine # U3019-31,if anyone has an idea on the year of manufacture let me know ,I am restoring to drive in parades..Oh it also has a zenith carb.. thanx
JMS/MN
11-07-2005 16:44:41
 Re: Finding a production year in reply to Butch W, 11-07-2005 14:20:40
Serial number is on the rear vertical face of the differential- left side, near a hole with a brake spring hooked into it. Will start with WD. Serial numbers are ALWAYS stamped- not cast. Number goes on near or at the end of the production line. Castings go on anytime befrore that-= numbers mean squat.
Butch W
11-09-2005 16:44:34
 Re: Finding a production year in reply to JMS/MN, 11-07-2005 16:44:41
Thanks for the response ,looked all over that area but,found nothing...a plate stamped on the engine block has WD283580PA...can anyone get a date from that # ,or am I just lost
JMS/MN
11-10-2005 07:27:50
 Re: Finding a production year in reply to Butch W, 11-09-2005 16:44:34
Engines can be changed, so the tractor serial number is what to go by. May be covered with paint- try wire brushing the area described. Also, very early WDs had the number stamped in the narrow strip of cast next to the left side of the brake cover. That would be on top of the differential. If you have an operator manual, you will see the picture showing that- tractor number 4004.
JMS/MN
11-10-2005 09:37:20
 Re: Finding a production year in reply to JMS/MN, 11-10-2005 07:27:50
Checked the book- it is to the right side of the left brake cover.
Butch W
11-10-2005 15:45:59
 Re: Finding a production year in reply to JMS/MN, 11-10-2005 09:37:20
Thanks for the help, I will check around that area..also the battery box is not original and covers alot of area on top the trany ,it could also be under that mess.. I am in the process of cleaning and wire brushing.that is how I found the engine # so I have many surprises in store for me..thanks again
JMS/MN
11-10-2005 20:50:20
 Re: Finding a production year in reply to Butch W, 11-10-2005 15:45:59
There is no serial number around the transmission on a WD. B, C, yes, but not a WD. It is on the differential.
Butch W
11-13-2005 09:12:16
 Re: Finding a production year in reply to JMS/MN, 11-10-2005 20:50:20
FOUND IT!!!! WD76801 it was buried under years of paint and visibility was faint, but this is the # on the tractor
