Eric, assuming the Genny and Voltage Regulator are probably?? okay I will say this: 1) Did you Polarize the new genny??? If not try that n see what happens. 2) Is she wired correct?? BAT on VR wires up to the ammeters Load (NOT to battery/starter) terminal ARM (or GEN) on VR wires to gennys Arm post FLD on VR wires to gennys Field post 3) For the genny to get to n charge the battery it must have a current path !!! If so and the VR is wired correct the BAT terminal on the VR MUST ALWAYS READ HOT BATTERY VOLTAGE. If it dont, make sure a wire from it gets up to the ammeters load (NOT to battert/starter) terminal. 4) If wired correct and good, BOTH the ammter terminals MUST ALWAYS READ HOT BATTERY VOLTAGE, do they??? Thats the path for the genny to charge the battery,,,,, ,from the gennsy ARM post,,,,,to the VR,,,,, through the VR to the VR BAT terminal,,,,, ,,to and through the ammeter,,,,, ,,,to the battery often via the big cable on the starter solenoid or switch. 5) Is the VR suitable for your ground???? Polarize her,,,,,mkae sure the VR to genny is wired correct,,,,, ,,make sure the VR's BAT terminal is always hot,,,,, ,,,,make sure BOTH ammeter terminals are always hot,,,,, MAKE SURE BOTH THE GENNY AND VR HAVE A GOOD GROUND !!!!! Lemme know and if still no charge I will post back more troubleshooting tips to see if its a VR or a genny problem. Does the ammeter work and what does it indicate from setting to wide open??? Youre correct, if shes charging the battery voltage should rise from 12.6 to over 13 volts at wide open. Lemme know, good luck n God Bless John T A D 15 owner and retired electrical engineer
