WD WD-45
Farm-all-the-way
11-06-2005 18:47:47
Hello there, I was just wondering what the differences are between the WD and the WD-45...and I was also wondering if the block off of a WD was the same as the block off of a WD-45. THANKS
Josh
Eldon (WA)
11-06-2005 19:42:51
 Re: WD WD-45 in reply to Farm-all-the-way, 11-06-2005 18:47:47
WD has 201 cubic inch displacement where the WD45 has 1/2 inch longer stroke giving it 226 cid. The 201 cid engine is easily spotted by the large rectangular plate bolted to the RH side of the block behind the mag/distributor. Late model WD's and all WD45s had curved shift levers and beveled gears, early WD's had straight cut gears (straight gear shift lever) and more tranny noise. WD45s also had an additional clutch plate in the hand clutch and came with the traction booster system. WDs after '51 or so had distributor ignition and all WD45s came with it. WDs typically had 13.6 x 28 rear rubber and the 45s had 14.9 x 28 rubber. WD45 was also available with a 6 cyl Buda diesel engine and later models had an improved 4 bolt wide front end.
old
11-06-2005 19:06:42
Differant blocks, the WD45 has more HP and a few other things.
ricedaddy
12-06-2005 17:21:53
 Re: WD WD-45 in reply to old, 11-06-2005 19:06:42
the wd has a 4" bore
compression ratio 5.75 to 1
compression pressure 110 lbs.
displacement 201 C.I.
wd45 is 4.5" bore
C.R. 6.5 to 1
compression pressure 90 lbs.
displacement 226 c.i.
they also ran different size tires
